Front lower control arms
Just want to make sure this is correct. I got teraflex front lower adjustable control arms. When you install you wait to tighten everything on the ground correct? An my jeep drifts to the right now, will the recommended settings for pass side being longer then the drivers side fix this issue? An any other tips would be good also. Thanks.
Cant help you about the settings but I can tell you yes wait until you have weight on it. Bounce the jeep up and down a bit to settle
everything then torque the arms down.
