Front Lower Control Arm Install Questions
Old 12-15-2011, 04:50 AM
AptPupil's Avatar
Originally Posted by mkjeep
One recommendation. Do not lactate on the jamnut, that will do no good, use loctite on them instead.
Win!
Old 12-15-2011, 04:54 AM
hneiper's Avatar
Originally Posted by Bnizzle
not sure but i think you should reweld them up from getting cut for the cam bolts....
Crap! Complicates things a bit. I wonder if new brackets are needed or just welding grade 8 washers or some type of plate metal and then drill the plate or something like that to the existing bracket.
Old 12-15-2011, 05:09 AM
JKred's Avatar
Washers will work fine, and now you'll have a round hole instead of a square one!
Old 12-15-2011, 05:26 AM
hneiper's Avatar
like round holes!
Old 12-15-2011, 05:34 AM
JKred's Avatar
like round holes!
Don't we all
Just make sure that the washer face is a big enough diameter to properly cover the slot, and that the ID is a snug fit the LCA bolt.
Quick Reply: Front Lower Control Arm Install Questions
