Front Lower Control Arm Install Questions
Originally Posted by Bnizzle
not sure but i think you should reweld them up from getting cut for the cam bolts....
Originally Posted by hneiper
Crap! Complicates things a bit. I wonder if new brackets are needed or just welding grade 8 washers or some type of plate metal and then drill the plate or something like that to the existing bracket.
like round holes!
Just make sure that the washer face is a big enough diameter to properly cover the slot, and that the ID is a snug fit the LCA bolt.
