Front end alignment 2011 jk
Old 07-26-2011 | 09:27 AM
Beto jk's Avatar
Default Front end alignment 2011 jk
Looking for front end alignment shop in livermore ca or nearby I have a 4 inch pro comp lift with 35s flighty steering need a jk specialist
Old 07-26-2011 | 10:41 AM
nthinuf's Avatar
Go down to JK Write-Ups
There is an Index stickied at the top
In the Suspension & Steering (and also the Troubleshooting) area, find the DIY Alignment writeup.
If it is flighty, your caster is too low. Assuming your lift came with adjustable control arms (or Cam Bolts?), it's an easy fix, and the write-up will show you how.
If you still have just your stock control arms, there is nothing you can do. Don't waste your money for an alignment!! And if you choose to waste it anyway, DON'T let them install cams.
And you might want to delete your other thread asking the same question.
Old 07-28-2011 | 07:36 AM
snl7271's Avatar
I agree with the previous post 100% I believe I had the same lift as you have on my 2007 and it drove really bad. Put on the AEV 4.5" premium with the caster correction drop brackets and it drove way better.
Quick Reply: Front end alignment 2011 jk
