Front DS angle and caster correction
Old 04-06-2012 | 07:09 AM
vulcan classic's Avatar
Default Front DS angle and caster correction
Hey guys,
Is it possible to correct both the front DS angle at the TC and front end caster using both front adjustable UCA's and LCA's?
I'm running an OME HD lift with a 1" coil spacer up front to compensate for bumper/ winch sag.
Old 04-06-2012 | 09:30 AM
river2c's Avatar
You can move the axle forward with the adjustable control arms but caster and front drive shaft angle are inversely related. As you increase the caster you put the front drive shaft at a steeper angle in relation to the pinion. The best solution is to compromise and only increase your caster to the lowest setting where the handling is acceptable. This is usually around 5 degrees +/- depending on the lift and your drive shaft angle won't be too steep.
Old 04-06-2012 | 04:15 PM
So I can get away with just font upper or lowers...my wheelbase is still close to the stock 95.4", then I need rear uppers to dial in rear pinion
Old 04-06-2012 | 05:23 PM
snopro269's Avatar
I went with front lowers and rear uppers
If you are thinking of pushing your rear axle back then get rear lowers at same time
I know Tera Flex ask you if you are thinking of pushing axle back because that means you need a longer arms in rear
Might be something to think about, it's not needed unless recentering
Old 04-06-2012 | 05:44 PM
I'm right at 95" wheel base now, stock was 95.4, so is this enough to be concerned about or can I get away with just rear UCA's for pinion and front LCA's for caster?
Old 04-06-2012 | 05:52 PM
snopro269's Avatar
That should be fine
Old 04-06-2012 | 05:56 PM
Topkicker1's Avatar
I installed the Rock Krawler 2.5 stock mod lift on my JK. Went with the progressive rate front springs due to the extra weight up front (winch and bumper). My castor was at 2.65 degrees after the install. The steering was very flightly and on uneven roads it would nearly change lanes. Added front adjustable lowers, dialed the castor just shy of 5 degrees, and now it's a pleasure to drive again. Rear pinion angle is fine on a JKU with a 2.5 lift. I'm not sure how steep the rear drive shaft angle is on a 2 door with a 2.5 lift. As already stated, just go w rear uppers unless you're trying to recenter the axle. Here's a shot of the RK lowers. Love the shape for added clearance.
Old 04-08-2012 | 05:13 AM
Sounds like a plan, gonna go with rear UCA's and front LCA's
Quick Reply: Front DS angle and caster correction
