Front Driveshafts
I disagree. One must consider the quality of the parts used, where and how they were made, how the are attached (e.g, adapter flange?), and what kind of warranty the manufacture provides. If you are having clearance issues, then diameter size matters too. Driveshafts are no place to skimp on quality.
JK-Forum Founder
fair enough. i guess my point was that "most" drive shafts i have seen and or run have been made well, most come with yokes and, assuming you're getting something like a 1310, have a diameter that's narrow enough to not be a problem. i don't know anything about this company and, probably should have just recommend what i know is good out there. having said that, i personally would recommend getting tried and tested shaft like the kind coast or je reel makes. with them, you will know you are getting a quality shaft and one that uses quality u-joints and components unlike shafts made by other popular companies.
JK-Forum Founder
unless you're installing a set of 60's under your jeep, you should be fine running a coast shaft without having to take any measurements. their shafts allow for enough travel to work on most any lifted jk's.
Ok thanks for the input..I will call and get price..Is it then called a OEM replacement?
