Front Driveshaft/T-case vibration?
that's what i'm thinking. it's not uncommon to knock off weights on a ds and you more than likely have one that is out of balance.
With regards to VIBRATION, which style of driveshaft (stock OEM flange or CV/double cardin U-joint) is more forgiving? I am looking into replacing my front driveshaft in the future (I have an auto trans) with an aftermarket 1310 DS. But debating whether I should get the 1310 OEM replacement so that I wouldnt have to replace the yokes or the 1310 CV version. My off roading is limited to only light trails and sand/beaches, so there wont be too much flexing...Thanks...
Thanks.......Is it a simple procedure as replacing the stock flanges w/the aftermarket yokes and torquing the pinion nut (on the axle) ~160ft lbs? I read the write up on replacing the driveshaft and it mentions getting the rotational TQ average and tightening the pinion nut in 5lb increments until the Rotational TQ is achieved...Maybe I am making too complicated as it is, but just worried about leaks and over tightening the pinion nut and destroying the crush sleeve........
I have had the same issues and the same guys commenting here have helped me out. It would be so cool if there was some way the average guy could adjust pinion angle and castor independently.
I may seriously consider the Spyntec free hub conversion with my next set of tires (and rims for the new bolt pattern). Does anyone know if the kits are sold with replacement rotors so that I wouldn't have to drill all four of mine? I really don't want to run spacers.
