Front driveshaft leaking at transfer case, Rzeppa seal
2.5 OME lift with teraflex LCAs. Castor is 5.1 driver and 5.4 passenger.
Could running that much castor be the cause of the leak? There is no apparent tear in the boot. I cleaned a section and drove for 20 miles or so at 60mph. Didn't leak during the trip. No vibrations unless I'm going 75mph plus which I've avoided.
JK-Forum Founder
yup. the more caster you have, the steeper the angle at your joints will be on your shaft. looking at your pics, the cv boot is pinching quite a bit and it has clearly been compromised. once you start hearing a ratcheting sound coming from it, it will be done. time to pull it and look for a replacement.
To add to what WOL said, the grease is being squeezed outta the boot, even if you don't see any tears, it's most likely coming from where the clamp is. Once it's gone , you'll start hearing the ratcheting sound.
I didn't think the caster was that extreme. Any other indicators it's about to go besides the ratchet sound? And would I hear that all the time?
Any way to get more grease in there until I get a new shaft?
JK-Forum Founder
oh, and no, you cannot put more grease in it and expect it to stay. you gotta know that your drive shaft spins really really fast and once the boot is compromised, there is nothing that will keep the grease from spitting right back out the moment you start driving.
JK-Forum Founder
if i haven't beaten this one to death already, if you go with his shaft, just make sure to upgrade the u-joints to spicer or neapco. he'll be mad as hell to hear you ask for it and most likley will say some nice things about me but trust me, the cheap u-joints that come standard with his shafts aren't worth it.
I may be doing an OME lift on my 2010 2DR this year as well and will need to replace the drive shafts. What drive shaft(s) do you recommend? A lot in my local Jeep community seem to go with Coast.
Go with the OME light/medium load springs or you'll get more then a 2/2.5 inch lift. With more lift comes adjustable track bars and a rear LCAs.
