Front driveline Fix
Old 02-19-2008 | 03:34 PM
Docwinkle's Avatar
Default Front driveline Fix
Ok fellers,
I installed a TFBB , a week ago and then read the treads about damaging the front drive line. as i installed the lift i removed the skid and decided i would mod it to miss the shaft all togeather. Heres what i came up with. Tell me what ya think.
I marked the skid while it was inplace before the lift using a sharpie. Then used a torch ( a cutting wheel will work....then grinded and repainted.
I didnt get a flexed pic but looks to clear w/o any issues.
no skid here.......just like seeing my baby.......rofl
Old 02-19-2008 | 05:02 PM
GlennH's Avatar
thats a simple fix for grinding issues.
Old 02-19-2008 | 06:04 PM
88Crusher's Avatar
does that cross member not support anything?
Old 02-19-2008 | 06:16 PM
nukeman's Avatar
Good idea, but I think I would reinforce the area that remains, maybe some 3/8" or 1/4" plate across the bottom?
Old 02-19-2008 | 06:26 PM
greggradwohl's Avatar
x2.... Could do nothing but good.
Old 02-19-2008 | 11:35 PM
Docwinkle's Avatar
Only the skid plate
Old 02-19-2008 | 11:36 PM
Docwinkle's Avatar
This is my next step....but i want to see how it dos before i go to the trouble.
It seems pretty stable so far. i post any new news as it comes up. it still bolts in the center aswell so there is still alot of support.
Old 03-09-2008 | 01:38 PM
AZJeeper's Avatar
I did something similar, but not as radical. Lowered the plate about 1/2" using washers and ground down the area directly beneath the front drive shaft. Ended up ripping the boot off anyway because it's the auto transmission pan that's the weak link!
Old 03-09-2008 | 06:12 PM
Renegade's Avatar
I didn't even take out that much and mine still bent when I slid over a large rock. Good luck with that. Hopefully it won't hit the side of the transmission like some are.
