Front Drive Shafts bent. Is it worth it to upgrade?
Found out my front drive shaft is bent. New from dealership is 239.00. Is it worth it to get an aftermarket? What are the advantages?
What do you all suggest?
Here's what you do ...
Find a local reputable driveshaft builder and take your jeep to him. Tell him to build you a heavy duty driveline and install it. It will cost you around half the price of one you can buy online and you will not have to install it yourself. This is what i did and it cost me $275 to have one built and installed. You cannot beat that.
Good luck.
Good luck.
Good luck.
Good luck.
If you stay with stock ones you will definitely be able to find some pretty cheap replacements on here. Considerably less than the dealer.
