Which front drive shaft?
Old 01-26-2016, 09:38 PM
sea bass's Avatar
Originally Posted by troyoffroad
Interested in this option. A lot cheaper, but I'll still have the stock shaft and joints which are weaker than ones I'm looking at. Anyone try this with long term good results?
Doesn't do anything to address the clearance with the crossover tube if that's a concern. That was my main reason for swapping the shaft to begin with.
Old 01-27-2016, 02:35 AM
DKJEEP's Avatar
Who said it's weaker? The rzeppa joint is stronger than a 1310 u joint. The shaft itself isn't weaker either. It is larger though.
Old 01-27-2016, 03:38 AM
Chuck-The-Ripper's Avatar
I'll be going the teraflop route with the front shaft. The rear I have an Adams and it seems to work as it should. I'll be keeping the stock shaft in front so as there'll be no problems with castor vs pinion angle as the rezeppa joint is much more forgiving.
Old 01-27-2016, 03:57 AM
TreyJK's Avatar
Another vote for Adams, seems to be a very well-made product.
Old 01-27-2016, 04:28 AM
jedg's Avatar
I'm running Adams 1310 in the front and 1350 in the rear now for about two years with a 6.0L driving them. I'm not much for 'giving it hell' to get over obstacles, but I've been happy with these drive shafts. I do keep the slip-joint greased and inspect the u-joints with every oil change.
Old 01-27-2016, 07:08 AM
kjeeper10's Avatar
I rebuilt a joint using TF's high angle housing. Never used it though. I sold it to a member on this forum, last time i checked in he liked it.
Old 01-27-2016, 07:42 AM
troyoffroad's Avatar
That looks like some good angle on there. I need to check my crossmember clearance at full droop and see if my stock shaft is hitting. If not, I'll probably go that route. If it is, I'll probably go with Adams 1350.
Old 01-27-2016, 09:48 AM
kjeeper10's Avatar
Heres another
Old 01-27-2016, 12:10 PM
nthinuf's Avatar
There are quite a few old threads and pics of people notching out the crossmember skid (or lowering it by adding washers) to provide a little more clearance. Just another option if you choose to stay with the stock shaft.
Old 01-28-2016, 04:59 AM
That reminds me, is that small crossmember necessary? Has anyone just removed it all together? Doesn't look like it does much for support.
Quick Reply: Which front drive shaft?
