Front dana 30 on 37s
#81
Interesting, hadn't seen that announcement.
So it looks like:
2.50" x 1/4" - Stock
3.00" x 1/4" - G2
3.25" x 1/4" - Tera44
3.00" x 5/16" - PR44
3.00" x 1/2" - PR44/U
I did not see any indication that the G2 is caster corrected?
Any pricing info? Or just a pre-release notice?
(Found some posts on another forum that indicate $2k for the bare G2 housing, same as PR and Tera. That forum also indicates thicker tubes, but G2 shows them as 1/4", not the 5/16" posted there. Think he got the tubes and brackets confused.)
Has the G2 actually been released? Or are you just going by hearsay?
So it looks like:
3.00" x 1/4" - G2
#82
G2 makes d44's for the TJ and WK, did they finally do one for the JK?. I think you're stuck with the Tera44 and PR44. Both should be priced about the same. Empty housings around 2k, fully loaded somewhere around 5k, depending on components. Guessing your 'double the price' comparison was an empty Tera44 housing vs a complete PR44? Fill the tera housing with goodies and re-compare.
#83
I just bought my 37s and am currently deployed my wife is planning on going to have them pu ton this weekend. The rear pinch seem has not been cut will she be ok to drive it from the tire shop to the house without messing up a tire? Its a 2011 2dr and has 3 inch plushride lift with factory control arms in the rear.
#84
#85
Yes i was. I was pricing the empty tera 30 to keep my almost brand new 4.88s and shafts. For the PR44 i would need new gears, shafts and whatever else. Core44 i would be in the same boat. Gears and shafts would make a 1k difference or more. Im also in canada. Our prices kinda suck up here.
I know it's pricey, but the pro rock 44 and 60 are amazing...
Matthew
#86
Interesting, hadn't seen that announcement. So it looks like: 2.50" x 1/4" - Stock 3.00" x 1/4" - G2 3.25" x 1/4" - Tera44 3.00" x 5/16" - PR44 3.00" x 1/2" - PR44/U I did not see any indication that the G2 is caster corrected? Any pricing info? Or just a pre-release notice? (Found some posts on another forum that indicate $2k for the bare G2 housing, same as PR and Tera. That forum also indicates thicker tubes, but G2 shows them as 1/4", not the 5/16" posted there. Think he got the tubes and brackets confused.) Has the G2 actually been released? Or are you just going by hearsay?
#88
