Front D44 Beef up question
Any ideas on costs for this option?
JK-Forum Founder
I forgot to point out that I already run 5x5.5 so the bolt pattern isn't an issue. Sorry for not mentioning that earlier.
I actually have some budget and can do upgrades. I really want to do the right balance of money and reliability, or possibly do something to "tide me over" until I have enough to go with a full 60.
I currently run a HPD60 in the rear with the tone rings and 5.13 gears, shafts and an ARB. I run the factory rubicon locker up front and 5.13 gears with high-steer, but no other upgrades. I ordered the Currie HD tie rod and am about to try and flip it.
I didn't realize I could get about $2K for the front 44. If so, that only leaves me about $2500 from the Dynatrac?!
but you would be installing it into a new housing. i'm no expert here but, i'm pretty sure you would still need to take care and at least double check your gear backlash setup.
Sponsoring Manufacturer
All of your existing Rubi front end parts can be swapped over to the PR44 housing. One of the most important improvements will be caster correction.
After you have the factory diff installed into the PR44 housing, the balance of the swap is very easy and could easily be done on a Saturday. This is also a good time to upgrade your ball joints which are likely to be bad if you have over 20K on the rig.
Thanks Wayoflife.
If I go the Dynatrac with my components, how strong is the factory locker?
Is this a good option or just a band aid to at least get an ARB and good shafts with the housing?
JK-Forum Founder
if it were me, yes.
JK-Forum Founder
assuming they are still good, you can reuse your ball joints. i think what dynatrac was referring to was not "camber" but "caster". they build their axles with positive caster in it already.
This is a good thread!
So I'm now leaning towards an axle swap instead of my D44 upgrade. That being said what are my options with the Dynatrac approach?
For example, What's a prorock44 and a prorock44 unlimited? Is there a difference? I know I need an ARB, so i'd probably like to keep my stock 44 complete so I can maxmize my re-sale and offset this new purchase.
I already run 5x5.5 so I'd probably like the manual hubs included in a solution. Can those axles we spoke about earlier be run with manual hubs?
