Front Coilovers done, Need Rears???
I've been running front King coil overs for about eight months now. Have to wheeling trips and has performed as expected.
My original thought was that I would run the front coil overs and when money was free I would invest and purchase rears.
My question is, are rear coil overs necessary?! The jeep has performed very well and the ride is quite good in regards to different springs and shocks from the front to the rear. I know this is generally a preference deal, and there would be no harm in getting them, but what is everyone's thoughts?
I would not bother if you are going to use one of the kits that hang them out the back in the factory locations. They will offer you more choices on coil rates and ride height though if you do go that route.
In the stock location they won't offer you any benefits that can't be achieved with a good conventional coil spring/shock set up. If you went with a custom set up such as outboarding them it is a whole different story.
Like desert crawler said there is not a lot of benefit you can't get if you spend the time to do it right with rear coils. Using the factory mounts limit your shock travel unless you are going to run a lot of lift. I also don't care to have shocks hang out back like that let alone a bigger coil over that can catch damage.
Just one guys opinion, but I've never been a huge fan of rear coilovers in a daily driver setup. There's too many variables in flux for the rear for me to feel confident in my abilities to setup a system that works well in all situations. A dedicated trail rig that's weight stays fairly constant, coilovers give you a few advantages. And the bolt on applications (in most cases) fall short in design, as already said. If you want to completely rework your rear end, with a whole new mounting system, then go for the coilovers, but if you don't want to use a sawzall and a gas axe then I would stick with a well tuned shock/spring setup in the rear.
DW
