Front bumpers with RV towability?
I figure this is the best place to start asking...
What aftermarket front bumpers are compatible with either adding a baseplate or as is for attaching a front tow bar for RV towing. I want to get something with more clearance than the OEM bumper so the tires don't bump the wings at max articulation. Might cut them off but a new bumper could work too.
I have an old Blue Ox towbar that could probably be successfully mounted on almost any bumper with a flat face on the front (with appropriate backing plates).
I see you have a Demco baseplate and I am not sure if any of the aftermarket bumper builders are working around anybody's baseplate.
We flat tow our Ruby when going wheeling a long distance away from home, 50+ miles one way.
We got a tow bar from U-haul and had it modified at the joining point, took the 1/2" pipe off and moded in 2 flat plates per side to be able to use the large clevase tabs on the front of our warn bumper.
Check out the Currie tow bar, works with the factory bumper!!!
http://www.currieenterprises.com/ces...t.aspx?id=2791
Thanks for taking the time to post those photos. That's exactly what I was looking for, hope it helps kb7our
Thanks for the input so far on a possible front aftermarket bumper that can accomodate flat towing. I don't care if I cannot use my Demco tow bar although I would like to keep it ideally. My personal favorite for a new bumper is the LoD full bumper which has hoops for D-rings I just haven't received a reply from LoD is to whether or not the holes can be opened up a bit to accomodate the larger pins most towbars have. Still on the hunt.
I just installed a MOPAR winch bumper and then added a set of Roadmaster tow brackets to pull the Rubicon behind my motorhome. I also installed an aux braking system manufactured by SMI inc.
