front brake line and lift help!!
Old 07-21-2014, 06:53 PM
  #31
phuggit's Avatar
I finally gave in and ordered extended brake lines. $130 well spent.
Old 07-21-2014, 07:08 PM
  #32
Invest2m4's Avatar
Do some reading on swapping brake lines on JKs. You want to avoid the squishy pedal issue. Simple steps: have someone plug the open line with their finger so fluid doesn't leak out. Attach new line to caliper, open bleeder and use a syringe to fill the line with fluid. Close bleeder, connect to hard line. Repeat other side. Bleed brakes.
If air gets into the ABS, it's bad news....
Old 07-21-2014, 09:25 PM
  #33
DJ1
Former Member
DJ1's Avatar
Originally Posted by JustJeepinWithYa
This is a great idea! As usual strong suggestions from invest2m4. Wish I had heard this trick during my install.
+2. You and me both
Old 07-22-2014, 03:18 AM
  #34
Monte417's Avatar
Originally Posted by 14Sport
You should be able to tell by looking at it. If the nut side comes out further than the head side then it would certainly help.
Not for her
Quick Reply: front brake line and lift help!!
