Front Axle
Sponsoring Vendor
You can read about the differences here, but their new unlimited housing has thicker tubes and built-in caster correction. Well worth the extra $180.
https://www.jk-forum.com/forums/show...-Forum-Members!
What is the most economical way of upgrading to something better than the stock 30?
can you find rubicon axles used anywhere
a $4500 axle assembly is not in my future, since I do not beat my daily driver
Can always try finding a take off from a Rubi to have 44s front and rear. But how many people do you know that are buying a Rubi to just rip the axles out and sell them. That's a hard search
The 'regular' PR44 is Dynatracs original housing/axle for the JK. It is a direct replacement, with the same caster specs as the factory JK D30 and D44 front axles. It is just a better housing. The 'unlimited' PR44 is Dynatracs newer version of the regular pr44. It has thicker tubes and has caster correction built in.
There are two versions of each. One will allow you to use all of the rubi44 components, you just remove them from your current rubi axle, install them in the new pr44 housing, then bolt it on. The other is for standard carriers like the ARB or Detroit locker. They are the same housings, with the exception of which carriers you can run. (a rubi carrier/locker can not be run in the non-rubi housing)
As far as cost goes, run down to your local dealership and see how much a new rubicon44 front axle is. Expect somewhere close to $3000. Then spend $500-700 for gears. Then weld on C gussets. Then weld on inner and/or outer sleeves. And bracket reinforcement. And a truss. --- and where do you think the price is going to end up??
A complete PR44 delivered to your door will be somewhere around $4500, and will be much stronger than that 'fully' upgraded rubi housing. The only time upgrading a rubi axle really makes sense is if you 'already own a rubi'...
