FOX vs KING shocks!!!
Sponsoring Vendor
ORW Representative
ORW Representative
I would go with the fox shocks over the king, they're pretty much the exact same performance wise and fall into the same price range. But I would also look into the Bilstein shocks since those are very comparable to the foxes and kings.
I have the King's 0-2 per say, but your going to need 1" bump stop in front not to bottom out on the shock and a 5/8's block for the bump stop for the back. Then your going to need a adjustable track bar to center your front axle for not to have the passenger side shock rub on the frame at full extended travel.
What can I say, I love them
EVO: King Shocks, Jeep JK Shocks w/Compression Adjusters KIT
PS: You will need 2" lift or go real slow on bumps on city street.
So close to being to go wheel again
The Fox 2.0 with reservoir and 8 way adjustability are a great shock for you aplication. That being said, I think they are designed for a 4" lift(unless they have a no lift model)
King are definitely one of the nicest shocks you can get. However, with that small of a lift, I don't think it's worth it. Might as well save some money and get Fox or Bilstein.
Are you planning to wheel it much? You're probably only going to notice a difference between expensive and lower end if you're wheeling it. Won't notice as much on pavement.
