Fox Steering Stabilizer
I just purchased a fox steering stabilizer, a relocation bracket (and I already have the EVO flip kit with its relocation bracket) and a steering stabilizer clamp. The installation instructions are non existent. Do I mount the shock with the body attached to the relocation bracket or steering stabilizer clamp? Do I install the clamp at the length of the shock?
Thanks
Thanks
Either way its mounted it works the same. And like the other poster said its not a just bolt on deal. You'll need to check left to right travel so you get it centered in the middle of its travel with tires straight. You'll need an extra body to steer while your underneath.
