Fox ATS WOW!!!
#32
Sorry crappy vid.
http://youtu.be/zuZ1-FHoNEc The wheel hardly moves with me loosely holding it. Tried to aim for the pot holes
#33
Another very satisfied user of the Fox ATS SS. The Fox ATS tightens the steering, smooths out bumps and potholes, and reduces drift in windy conditions. A good test was driving over a washboard dirt road that we use to get to our off-road trails. It also dampens the rough bridge joints I drive over every day.
FYI, after I busted my stock SS, I installed a cheap RC SS, because after all, according to forum wisdom there is no difference in quality between brands. Just buy the cheapest replacement. Wrong. There is no comparison.
#36
#38
The one that mounts to the trackbar bracket. Im assuming you didnt use the trackbar bracket from the fox kit because you wanted to use the 9/16 bolt. If you want to continue to use the 9/16 bolt do you need that trackbar bracket from synergy? Just want to see how you have everything mounted up. Thanks
#39
Fox used a 2 sided bolt that actually replaces your factory 14mm bolt. One side is 14 mm and the other is 1/2 which the stab mounts to.
I'm using a raised track bar bracket with a flipped drag link. Just so happens to have 2 holes for mounting a stab.
Look at the fox 2.0 shock with the bracket I posted earlier. People will modify that bracket to work with the ATS.
#40
Gotcha
