Fox ATS WOW!!!
Old 10-09-2013, 05:03 AM
  #31
kjeeper10's Avatar
Northridge code shark tank $319 for the ATS I was told
I filmed a short video. Waiting to process. Shitty but shows how well it works. Will post soon
Old 10-09-2013, 06:38 AM
  #32
kjeeper10's Avatar
Sorry crappy vid.
http://youtu.be/zuZ1-FHoNEc The wheel hardly moves with me loosely holding it. Tried to aim for the pot holes
Old 10-09-2013, 07:57 AM
  #33
brighton's Avatar
Another very satisfied user of the Fox ATS SS. The Fox ATS tightens the steering, smooths out bumps and potholes, and reduces drift in windy conditions. A good test was driving over a washboard dirt road that we use to get to our off-road trails. It also dampens the rough bridge joints I drive over every day.
FYI, after I busted my stock SS, I installed a cheap RC SS, because after all, according to forum wisdom there is no difference in quality between brands. Just buy the cheapest replacement. Wrong. There is no comparison.
Old 10-09-2013, 08:09 AM
  #34
hair2831's Avatar
I think this is going to be my next mod. Reviews sound great!
Old 10-09-2013, 08:25 AM
  #35
kjeeper10's Avatar
100% worth it. I honestly didn't know people were running it on a stock jeep.
Old 10-09-2013, 08:29 AM
  #36
Monte417's Avatar
Originally Posted by kjeeper10
Yes ... I've seen others DIY a bracket with w 1/2" hole.
Is there any chance you can post a pic of this mounted with the synergy bracket
Old 10-09-2013, 09:26 AM
  #37
kjeeper10's Avatar
You want a pic of the synergy bracket that flips the SS.
Mine is the raised TB bracket which has holes already for the SS.
Old 10-09-2013, 10:10 AM
  #38
Monte417's Avatar
The one that mounts to the trackbar bracket. Im assuming you didnt use the trackbar bracket from the fox kit because you wanted to use the 9/16 bolt. If you want to continue to use the 9/16 bolt do you need that trackbar bracket from synergy? Just want to see how you have everything mounted up. Thanks
Old 10-09-2013, 10:57 AM
  #39
kjeeper10's Avatar
Gotcha
Fox used a 2 sided bolt that actually replaces your factory 14mm bolt. One side is 14 mm and the other is 1/2 which the stab mounts to.
I'm using a raised track bar bracket with a flipped drag link. Just so happens to have 2 holes for mounting a stab.
Look at the fox 2.0 shock with the bracket I posted earlier. People will modify that bracket to work with the ATS.
Old 10-09-2013, 11:43 AM
  #40
Monte417's Avatar
Gotcha
Awesome thanks
Quick Reply: Fox ATS WOW!!!
