Fox ATS WOW!!!
Old 10-08-2013 | 10:01 AM
  #21
kjeeper10's Avatar
Vet Army
Originally Posted by Monte417
does it come with a bracket to mount to the trackbar bracket. I would hope installing this doesnt require you to lose the 9/16 trackbar bolt. that bolt is kind of important
It does come with a TB mounting bolt.
TB side is 14mm and the shock side is 1/2
Did not want to remove the 9/16 bolt securing my the track bar. It mounted nicely to one of the holes in the synergy bracket.
Old 10-08-2013 | 10:04 AM
  #22
kjeeper10's Avatar
Vet Army
Originally Posted by patricks99
I think what familytime was referring to was the OP says it fixed all of their steering issues. If you are having steering issues there are usually other things going on, the dealer usually likes to tell you when you go in with steering issues it's the stabilizer, all that does is mask the problem until the stabilizer wears out and you are back to where you started.
Not exactly... I said I pretty much fixed all my steering issues and posted what I've done. This stab just adds the finishing touch.
I guess that could of been misunderstood.
Old 10-08-2013 | 10:20 AM
  #23
Monte417's Avatar
Cool thanks im assuming you used the 1/2 bolt to mount the SS to the synergy mount?
Old 10-08-2013 | 10:23 AM
  #24
kjeeper10's Avatar
Vet Army
Yes ... I've seen others DIY a bracket with w 1/2" hole.
Old 10-08-2013 | 10:27 AM
  #25
TJJK's Avatar
OP said that he had fixed his steering issues and the DAMPER was the finishing touch- so no masking, just enhancing. Was kinda surprised that someone would bust the OP's chops with the first reply.
Old 10-08-2013 | 12:25 PM
  #26
Pepsi's Avatar
Originally Posted by familytime
What's that at the end of the stabilizer near the diff cover?You may think you fixed your steering problems but you just put a band aid on it.A jeep that's been fixed of steering issues is running no stabilizer
I have no steering problems not even a lift and im thinking about installing a fox ss and chromoly tie rod just for better handling and feel, so before you talk smack realize everyone has there likes.
Old 10-08-2013 | 02:07 PM
  #27
kjeeper10's Avatar
Vet Army
Haha.... Stabilizers are a touchy subject. I'm not a newby trust me
99.989 stabilizer post go like this
"Had DW dealer replaced SS and it's now gone"
Or
"Will a stabilizer fix my DW"
Or
"Bumpsteer = stabilizer bad ? "
Or
"Help DW" .... "Replace your SS with a HD"
Etc etc etc etc
-The words bandaid and mask get used 100 times
Then of coarse. the cool guys that don't run one at all, and they can do 95 with 1 figure over bridge abutments,
I should have been more clear with my review/post. He is 100% correct
Old 10-08-2013 | 10:47 PM
  #28
Fugg it's Avatar
Or
Or
Or
Etc etc etc etc
^lmao! Truth! The cool guys running none lol
Old 10-09-2013 | 04:40 AM
  #29
GoBig's Avatar
What did you guys upgrade from? I have an OME ss by ARB and really like it.
Old 10-09-2013 | 04:49 AM
  #30
brian3033's Avatar
I upgraded my 5 yr old stock stabilizer to the fox. I didn't have any issue to start with but the new stabilizer feels way better than my worn out stock POS and looks cool too.
Quick Reply: Fox ATS WOW!!!
