FOX ATS Warning!
Thanks for the heads up on the tie rod clamp. Although for the guys that have the shock body roll over, I don't see how that's possible unless you loosened the allen screw or didn't tighten it back up so it wouldn't move. Or maybe it just doesn't clamp down hard enough but I haven't seen any movement for the few months I've had it.
Talked to Fox today. Had to send them pics cause they didn't understand what I was talking about. They wanted to make sure it wasn't installation error. I told them it couldn't be installation error on my end cause it was a part they put together. Still waiting to hear back.
Gonna slap a Rough Country on for now cause I tossed out my stocker.
ill hold off on buying one
till they work out the crappy design flaw/ keep posting on the outcome I was thinkin of picking one up next as my next mod ill keep the stock one for a bit now
Just to be clear on my posts. My issue, although it looks like the same problem appears to have been caused from the Teraflex track bar knuckle spinning and ultimately hitting and damaging the fox steering stabilizer. There is a known issue with cheap hardware on the Teraflex that loosens up. Replaced the hardware and will be sending in my fox for a rebuild.
Fox is taking care of my stab under warranty. After looking at the pics they aren't sure whether they're gonna rebuild it or replace it.
They should get it Monday. Probably get it back in about 2 weeks. Hopefully.
Have to make a point of checking that bolt at every oil change.
at least the covered you
thats good tp know seeing the cost of the shock it should be quality yould expect
it looks decent (did you see any major improvement in ride from stock ss ?)
