FOX ATS Warning!
Old 02-01-2015, 07:00 PM
evoviii2jk's Avatar
Originally Posted by 46chevytruck
Mine did the same. I sent in photos and never heard back. I need to followup. Way too expensive to have issues like this.
What did they charge to rebuild it?
They rebuilt it for free as it right at the warranty cutoff
Old 02-01-2015, 07:02 PM
evoviii2jk's Avatar
Originally Posted by DJ1
Thanks for the heads up on the tie rod clamp. Although for the guys that have the shock body roll over, I don't see how that's possible unless you loosened the allen screw or didn't tighten it back up so it wouldn't move. Or maybe it just doesn't clamp down hard enough but I haven't seen any movement for the few months I've had it.
My allen head was beyond tight...i think it was missing some small part inside to keep it from moving
Old 02-02-2015, 03:56 AM
FDHog's Avatar
Is this the clamp that holds the shock to the bracket with 1 allen head screw or the tie rod clamp with the 4 screws?
Old 02-02-2015, 04:54 AM
evoviii2jk's Avatar
It was the tie rod side just on the round part of the body. There is an allen head that squeezes the clamp side to the body. That whole part was spinning
Old 02-02-2015, 12:31 PM
FDHog's Avatar
Talked to Fox today. Had to send them pics cause they didn't understand what I was talking about. They wanted to make sure it wasn't installation error. I told them it couldn't be installation error on my end cause it was a part they put together. Still waiting to hear back.
Gonna slap a Rough Country on for now cause I tossed out my stocker.
Old 02-02-2015, 01:40 PM
evoviii2jk's Avatar
Yeah luckily I still had an unused one from my aev lift. Honestly it's pretty nice....im not in a huge rush to get my fox back on
Old 02-02-2015, 02:13 PM
jeepmojo's Avatar
Default ill hold off on buying one
till they work out the crappy design flaw/ keep posting on the outcome I was thinkin of picking one up next as my next mod ill keep the stock one for a bit now
Old 02-04-2015, 09:50 AM
46chevytruck's Avatar
Just to be clear on my posts. My issue, although it looks like the same problem appears to have been caused from the Teraflex track bar knuckle spinning and ultimately hitting and damaging the fox steering stabilizer. There is a known issue with cheap hardware on the Teraflex that loosens up. Replaced the hardware and will be sending in my fox for a rebuild.
Old 02-05-2015, 03:37 PM
FDHog's Avatar
Fox is taking care of my stab under warranty. After looking at the pics they aren't sure whether they're gonna rebuild it or replace it.
They should get it Monday. Probably get it back in about 2 weeks. Hopefully.
Have to make a point of checking that bolt at every oil change.
Old 02-05-2015, 05:40 PM
jeepmojo's Avatar
Default at least the covered you
thats good tp know seeing the cost of the shock it should be quality yould expect
it looks decent (did you see any major improvement in ride from stock ss ?)
Quick Reply: FOX ATS Warning!
