FOX ATS Steering Stabilizer Install Question
Got mine all in, it looks good and drives great. I would say, just like others, that there is a very noticeable difference when driving. I went over speed bumps, pot holes, and expansion joints and with the Fox ATS and my new ball joints it feels as solid and secure as driving a Mercedes. One thing though... I backed off the adjustment screw, then went to tighten it when it got it all in stalled and I turned it a bunch clockwise and it never stopped turning. Is this normal? I figured here would be a point where it stops turning once its gets to the tightest adjustment....
Sent from iPhone moderating JK-Forum.com
I did not jack mine up either. Just had a neighbor crank the wheel with the jeep running. Worked just fine.
Also I had the issue with the tie rod clamp, I took a hand held torch that would typically be used for soldering, heated it up and clamped a pair of vice grips on both ends and started pulling with one hand and pushing with the other. Took a while, but got her opened up enough to come off.
