FOX ATS Steering Stabilizer Install Question
Old 11-16-2013, 02:55 PM
k0260's Avatar
Originally Posted by Brightwhite
Got mine all in, it looks good and drives great. I would say, just like others, that there is a very noticeable difference when driving. I went over speed bumps, pot holes, and expansion joints and with the Fox ATS and my new ball joints it feels as solid and secure as driving a Mercedes. One thing though... I backed off the adjustment screw, then went to tighten it when it got it all in stalled and I turned it a bunch clockwise and it never stopped turning. Is this normal? I figured here would be a point where it stops turning once its gets to the tightest adjustment....
I'll have to check mine, seems like it should stop turning at some point. Mines set on 16 clicks for now
Sent from iPhone moderating JK-Forum.com
Old 11-16-2013, 02:59 PM
kjeeper10's Avatar
Yes it stops at like 26-27
Old 11-16-2013, 04:08 PM
Jeepstin12's Avatar
No need to lift it. Check the positioning and set the clamp in the proper place. Helpful to have someone turning the wheel while you indicate placement.
Old 11-17-2013, 05:34 AM
Brightwhite's Avatar
I did not jack mine up either. Just had a neighbor crank the wheel with the jeep running. Worked just fine.
Also I had the issue with the tie rod clamp, I took a hand held torch that would typically be used for soldering, heated it up and clamped a pair of vice grips on both ends and started pulling with one hand and pushing with the other. Took a while, but got her opened up enough to come off.
Old 11-20-2013, 03:59 AM
Monte417's Avatar
Mine does not stop turning in either direction so not sure what setting I'm on are sure it should stop?
Old 11-20-2013, 04:36 AM
kjeeper10's Avatar
Call FOX. There's def a problem.
Old 11-20-2013, 04:56 AM
Monte417's Avatar
Figured as much thanks
Old 04-02-2016, 06:26 AM
artieandgumbo1's Avatar
Default Adjustments
From what I can tell, the higher the adjustments=road. To adjust higher, I'm guessing twisting it clock-wise?
Quick Reply: FOX ATS Steering Stabilizer Install Question
