Fox 2.0 stabilizer, model 980-24-986 pulling to left
Yep, mine pulls since the day I've put mine in. I'm running about 35psi in mine. The shop that I bought mine from had the tool to take some pressure out of it. You may be able to buy the tool from Fox to do it yourself, but I'm not sure. I've heard of guys running less psi, but Fox told the shop that I'm using to not go below 35. The pull is annoying for sure.
From what I have read on previous posts, the pulling is common with nitrogen filled SS like Fox and Bilsteins. That is why I went with the new Fox ATS so I could negate the dreaded pull.
What's your impression of the ATS? I've been thinking About making the same move. Is the range of adjustment pretty noticeable?
I like it. Expensive, but I liked the principle behind it and that it is designed to be mounted above the tie rod so no additional clamps to buy. Depending on your adjustments, you will notice a difference in your steering response/feedback. I have Fox shocks also so I wanted to keep brand integrity. I think you would be pleased with it
