Flighty Steering / Bump steer
#21
Originally Posted by renpia
Did I read one of your post correctly and you don't have front LCA's?...
#22
Having the front uppers and rear lowers will allow for maximum adjustment of the axle position and pinion angle. I'm still debating on the Tera flip kit - just not a fan of having to drill into the knuckle to install it
#24
Ok. Had our front end technician take a look at the JK this morning to see if we could figure out what was causing the DW issues. He went over the front end in great detail checking all components for wear and making sure everything was good and tight. Drag link is good, ball joints look good, tie rod ends are good, toe-in is good, track bar bolts are good and tight, holes aren't wallowed out, control arm bolts are torqued to spec, track bar is torqued to spec, steering gear box looks good (but he said, without a steering dampener, it will cause the steering gear box to go out eventually). Camber is off just a little, but not by much. Caster is at 3.9* which he said should be good - more caster would help highway driving but would cause issues with the front driveshaft eventually, so that's good as well. Only thing he can think of is to put a steering dampener on and see if the wobble exists. He thinks the lack of a dampener will cause excess wear and tear on the steering gear box and the heavier, taller, bigger 35s will make it susceptible to excessive bump steer which would lead to wobble.
Thoughts anyone? I've been over planman's DW diagnosis thread several times and gone over that checklist a couple of times. Nothing that culd be the cause seems to be put of place . This thing's got me stumped big time. And I must add that the tires were just balanced less than a month back - but if anyone thinks I need to do at again, I probably will. I'm waiting for the wife's JK to get done with the Bodyshop work and might even swap stock tires on for a day to see if it's not tire related, even thought it does not appear to be - just to eliminate a bent wheel scenario
#25
#26
I had very similar results after I upgraded my rig, it turned out to be the stabilizer (okay, everyone stop, I know Planman says it will not cause it), however an incorrectly placed steering stabilizer can. I would start with checking WHERE your stabilizer is installed, and also verify it is working correctly.
#27
Originally Posted by Torrin
...I would start with checking WHERE your stabilizer is installed, and also verify it is working correctly.
#28
Originally Posted by jwhitehorn
If I am not mistaken, I do not believe Interceptor is running a SS... not, atleast, until he diagnoises the source of his DW
#29
If you are stumped with everything you had checked, why not consider the flip kit? The drilling of the knuckle is not a big deal, you are just drilling through the taper so the drag link can be flipped. The flip kit corrects steering geometry and roll center which not only improves handling but also eliminated my bump steer.
