Flex problem
Old 11-13-2013, 09:20 PM
D_engel's Avatar
Originally Posted by kjeeper10
I've also seen a few people double shear the frame side mount.
Huh? Can you explain what you mean by this?
Old 11-14-2013, 03:06 AM
m&kknox's Avatar
I had the same problem when I installed my lift. I just moved the axle forward enough to clear the bumpstops. My tire is still centered In the fender well and I haven't had anymore problems with it.
Old 11-15-2013, 08:36 PM
kjeeper10's Avatar
This... A secondary bracket welded to the stock mount to move the TB back some. Click image for larger version
Old 11-16-2013, 06:31 AM
TheDirtman's Avatar
That is exactly what I was talking about.
Old 11-16-2013, 08:03 AM
Flexer07's Avatar
This... A secondary bracket welded to the stock mount to move the TB back some. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=511534"/>
where do you get bracket or do you make it
Old 11-16-2013, 11:49 AM
Maertz's Avatar
when i stretched mine i got a weld on adjustable track bar bracket from ballistic fabrication. Thats rubbing your track bar right off lol.
Old 11-16-2013, 07:46 PM
TheDirtman's Avatar
I just made them out of 1/4" steel, just line it up so you can get the hole in the right spot and weld it on. Simple and cheap, takes about 15 min to do.
Quick Reply: Flex problem
