Flex problem
I had the same problem when I installed my lift. I just moved the axle forward enough to clear the bumpstops. My tire is still centered In the fender well and I haven't had anymore problems with it.
I just made them out of 1/4" steel, just line it up so you can get the hole in the right spot and weld it on. Simple and cheap, takes about 15 min to do.
