Flex problem
Flex problem
I have the rock krawler 3.5 X factor and my rear track bar is bottoming out on my bump stop on passenger side has anyone else had this problem.
if the bumpstop extensions are anything like teraflex's, they extend forward from the axle to allow users to push their rear axle back and still retain a proper bumpstop pad. You may have them on backwards
The track bar mounting location is hitting the bump stop bad. So rotating the track bar will not help. I do have teraflex bump stops that extend forward.
Are your arms adjusted to the correct lenght? I installed a buddy of mines lift, and his trackbar bolt was coming in contact with the bumpstops. We were able to trim the bumpstops to clear(His stops were steel.)
I recently installed another guys 3.5 X-Factor kit on a 4dr, and didn't have that issue at all when arms were adjusted to RK specs.
Are your arms adjusted to the correct lenght? I installed a buddy of mines lift, and his trackbar bolt was coming in contact with the bumpstops. We were able to trim the bumpstops to clear(His stops were steel.) I recently installed another guys 3.5 X-Factor kit on a 4dr, and didn't have that issue at all when arms were adjusted to RK specs.
