Flat tow recommendations
I'm looking to flat tow my slightly modded 12 rubicon behind my RAM 2500/four wheel camper set up. play form basecamp type thing. looking for opinions on the best way to do this.
details
12 Rubicon 2 dr
AEV 2.5" lift
33"s
LOD signature series mid width bumper
im thinking of using Warrier products D ring adapters with maybe a blue ox 6500lb tow bar or equivalent, thoughts? with this set up how do you do safetly chains? or am i better off bolting tow bar brackets to the bumper and using the D-rings for safety chains
wiring? do i need a battery disconnect for a '12? im seeing conflicting info on this that after 09 you dont need to keep the key in the ignition (no steering lock) jeeps not home now so i cant confirm. hear Cooltech is the way to go here
so, what have people done?
details
12 Rubicon 2 dr
AEV 2.5" lift
33"s
for the wiring I used cool tech wire harness, it plugged into the rear light harness on the jeep. I ran it from the front to the back thru the frame, very clean
http://www.cooltechllc.com/
cool tech harness is a must use from what ive learned
thinking Blue Ox Alpha Tow bar (6500lb)
Warrior Products D ring adaptors
and Roadmaster Invisibrake brake system
thoughts? i didnt plan on buying a brake system, see how it felt. after reading i think i should have one since in live in CO
I tow a 2012 2 door behind my Ram 3500 and camper. I have 33's, 2.5 AEV lift and an XRC bumper. I use a simple tow bar attached to 2 additional bolt on d-ring brackets which are bolted to the lower part of the XRC bumper. My safety cables attach to the regular d-rings on the bumper. I installed the Mopar harness which plugs into the factory harness under the right side of the dash.
I had to build a receiver extension to get the receiver out to the back of the camper. I use a brake buddy but have set it only to activate in hard braking situations.
several threads full of info
https://www.jk-forum.com/forums/modified-jk-tech-2/tow-bar-recommendations-2008-jk-335294/
https://www.jk-forum.com/forums/stock-jk-tech-12/flat-tow-jk-rv-332678/
https://www.jk-forum.com/forums/camping-hiking-99/towing-jk-behind-rv-88765/
https://www.jk-forum.com/forums/modified-jk-tech-2/towing-jku-behind-motorhome-329939/
