Flashlight mounting question
Just making some small brackets to screw to the frame and light mounts would be all you need. Fairly basic, I don't think there is a write-up on it. Grab some brackets from lowe's and you should be able to get it done pretty quickly/cheap
Mag makes mounting brackets for the lights. Pretty simple to pre drill the holes and mount the brackets. I suggest mounting it as far back as possible.
I mounted mine a little to close to the front and sometimes kick the front of the light when I get out of the jeep. No big deal but I might move it back some day when I have NOTHING else to do
Lowes and Home Depot did not have brackets that would work. I almost ordered them online, but found them at ACE. So look around.
Definitely get the maglite ones.
