Fix my thinking on lockers
Have you checked into which lockers / limited slips will work in your "rubicon" housings? And for which shafts (spline count)? Should you choose to replace, you might end up with a smaller set of options than you think.
Also, check your local craigslist or whatever and see how much you might be able to get for a used factory locker. The price difference between selling and buying a new unit could influence your decision one way or the other.
Regarding the posts about gear-driven limited slips - (with a link to a site dedicated to racing cars on pavement?) - what I did not see mentioned is that a little brake pressure is all it takes to provide the resistance needed to transfer power. In the case of the JK, the BLD system does that automatically, no driver foot pressure needed. There have been many previous posts indicating that the system works well to augment the truetrac. I would offer a suggestion to search out more posts on the Truetrac before scratching that one off your list...
Rich Hanner (01-28-2021)
nthinuf makes a good point about the BLD. I did mention applying brakes to relock the LSD and you could actually approach an obstacle with the brake pedal slightly applied to keep lock up.
This thread appears to be an extensive discussion about BLD and trutracs
https://www.wranglerforum.com/thread...lained.803194/
When I wheel I simply use the rear locker a lot and have my finger on the trigger to lock the front diff approaching an obstacle that I may think needs the locker then after that I unlock both and set the rear again if needed. Figure this way the diffs are not locked constantly therefore the electromagnet inside does not stay energized. Mine is 12 years old and is still original diffs, axles etc. Now with V8 and still good after the first year of wheeling. I think I can speak for all of us and say "it all depends on how hard you are on your vehicle". My vote is stay with the front stocker locker as others suggest.
doc5339 (01-28-2021)
Re-gear and go. You should rarely, if at all, need to use the locker. Most people I see on the trials use the locker way too much. The only reason people don't run selectable lockers is the price.
I would add a rear locker or LSD while your re-gearing. You'll get the most use out of it in the rear and the cost isn't crazy to add in most cases. I only did gears at first to avoid breaking the bank, only to go back and add a rear locker later, paying for labor twice. (or 3 times in my case)
If you go off road, lockers are great to have even if you don't "need," them. I have a nice Eaton-Elocker in the rear and a LSD in the front. I choose the Eaton as the system seems less complex and costly as you don't need the air compressor set up.
Pre-pandemic I had a blast using the locker going up some sand dunes in Michigan. For me, that one instance of fun paid for the locker. To compare, a nearby JL Rubicon (only locks in 4Lo) and JK Sport that tried did not not make it up, and my anemic 3.8l nearly flew over the crest each time. Certainly driver input makes a world of difference, and I imagine those jeeps eventually conquered the hill.
I would at minimum put a EATON Limited Slip in the rear. I have had the MOPAR one and the clutches wear out very quickly, making it into an open diff, and I also had the POWERTRAX one and it ate it's own gears. You will get the benefit of the LSD one the road. That, to me is the biggest benefit to the LSD in the rear.
Rich Hanner (01-29-2021)
horrocks007 (01-29-2021)
