Finally done w/my onboard air---ARB dual compressor
#23
If you can't find the leak in your connections or hoses, try to throw a check valve upstream of the reservoir if you haven't already. Some compressors can back leak.
#26
It's pretty loud acutally. With the tank it barely comes on while running one locker or even two at once.
#27
Just finished it up today. Painted the brackets black and got everything remounted. The system consists of: ARB dual compressor (CMKTA12), ARB locker manifold kit (171503), three ARB switches (compressor, front locker, rear locker----these were included with the compressor and lockers), a 2 gallon ViAir tank, two homemade brackets, and a few push lock fittings and some 3/8" hose. The ARB kit was a breeze to install. Very nice kit and the instructions were great. I wanted the tank out of the elements to keep it from getting beat up and rusting. Shouldn't be a problem under the seat as long as I don't let moisture build up and cause rust. Here are some pics.
Bracket for compressor and manifold:
This shows bracket mounted without compressor, but I mount the compressor first and then install them as a unit:
Compressor mounted to bracket:
Compressor and bracket mounted as a unit:
Bracket for tank:
Tank with regulator and safety valve:
Tank installed under driver side rear seat:
And the switches mounted to factory trim piece:
Bracket for tank:
#28
Can I ask you to post a diagram of your air system. I'm curious about the relationship between the tank, arb solenoid, and lockers. I also have an arb twin with a Viair tank and I'm not sure if I want to do arb lockers or ox. If you could elaborate on how those components come together I'd appreciate it! Thanks!
