FINAL decision on lift kit, help?! PLEASE
So im now deciding between the teraflex 2.5 in lift with bilstein shocks or the Rancho 3 in trail kit with XL shocks. The kit will run 35's. My question is will I need to change the driveshaft on the 2012 JK sport automatic with 3.2 gears and if anything else will be needed besides regearing which i was thinking 5.13s?
Cheers!
Cheers!
I'm running 35's on top of a 4" pro comp susp lift. Very happy with it. Mine is a 2010 with 3.73s but i plan to regear in the future. She can be a bit sluggish on steep hills but other then that i'm good with it as is. I don't do hard off roading (beach/light mudding) and I live in Central texas where it doesn't get EXREMELY hilly but enough to have challenged the stock gears and having me dreaming about some 4.88s
Cheers!
Cheers!
Replacement drive shafts:
During high articulation events, the front driveshaft may contact exhaust or transmission oil pan. A smaller diameter drive shaft is suggested for optimal performance.
Upper Adjustable control arms, brake lines and adjustable track bar......
Good luck with your choice! And have fun on the trail.
Since this is on a 2012, we offer an exhaust exhaust pipe upgrade as well
