A few POR15 Underbody/Frame Q's
Old 04-17-2018, 10:08 PM
vonlupus624's Avatar
Default A few POR15 Underbody/Frame Q's
I couldnt take the rust that was beginning to take hold on my 2013 JKU with only 30k on it. Long Island and salt :( I finally set aside some time and pulled the trigger on all the prep mats and taking caring of it, hopefully permenently
Will be cleaning, POR15 Degreaser, POR15 Metal Prep, then POR15 black semi gloss black. Skipping topcoat, prefer the fade to gloss.
My questions lie in which parts do I need to be avoiding when prepping.
1. What should I avoid spraying the Metal Prep on after degreasing? It contains a chemical that etches into the metal and leaves a "coating", allowing the POR15 to adhere to rust or smooth metal. Other than the brake lines... where should I be weary of?
2. What should I not be applying the POR15 semi gloss to and taping off? Avoid drive shaft because balance issues? What else do I avoid?
And what am I forgetting? Mats: impact with wirebrush, drop sheet, respirator, 1" bristle brush x12, 2" foam brush x12, POR15 Degreaser, Metal Prep, Semi Gloss, 6oz cups, latex gloves
Tip tricks or game genie codes? Thanks!
Old 04-17-2018, 10:17 PM
Rednroll's Avatar
I can't help you, but all that sounds too complicated for me to think about after reading what you described needs to be done.
Thanks, I'll stick to my method.
Coming up on 150K miles rolling in rust belt Michigan.
Old 04-18-2018, 02:41 AM
rob_engineer's Avatar
I did my drive shaft. I put my jeep on jacks stands, all four corners. Wheels removed to gain better access to more parts to spray. To do the drive shafts evenly I put the Jeep in 4-LO and actually had the hubs and shafts turning as I painted. I let it turn a little after done painting so would dry some while still rotating. I did not do the degreasing prep phase and regret that. Some spot my por-15 is peeling off.
Old 04-18-2018, 03:59 AM
Soooo, what is your method?
Old 04-18-2018, 04:08 AM
Rednroll's Avatar
I don't want to take over the thread or discourage anyone from their planned out methods unless they're interested in SIE
1. Simple
2. Inexpensive
3. Effective
Many tend to equate if it's Simple and Inexpensive then it must not be effective.
Old 04-18-2018, 06:20 AM
resharp001's Avatar
Received 1,945 Likes on 1,702 Posts
Dear lord I'm so glad I don't live in an area I have to worry about rust. I think about that every time I crawl under it to do something. Can't imagine the beating you guys have to deal with protecting the underside!
Old 04-18-2018, 06:52 AM
Rednroll's Avatar
I try to look at the bright side. Gives me one more excuse to get out of the house and work on my Jeep.
Old 04-18-2018, 07:04 AM
JKcity's Avatar
I think you just avoid rubber and plastic with the metal prep.
Old 04-18-2018, 06:44 PM
1. Simple
2. Inexpensive
3. Effective
Many tend to equate it to that because its a difference in ideology from how they think.
I can only assume that you rattle canned it and touch up when need? Which is, exactly, what I am trying to avoid, and the opposite of how I think. I'm more of the "do it right or do it twice" type of thinking, and while you see it as overwhelming and too much to do, I see it as a fun endeavor to drop a little coin on top quality products, and spend an afternoon doing all the proper prep because at the end of the day its rewarding as hell to see all your hard work and to know the quality is of the highest caliber, and that the job is done and done forever. Just get to smile at it now , and not worry about having rattle cans on hand for touch ups for the aforementioned "...do it twice"
having said that, yours looks great! Any plans to spray the muffler with heat friendly paint?
Old 04-18-2018, 08:22 PM
resharp001's Avatar
LOL..... You and rednroll are more alike than u think.
Quick Reply: A few POR15 Underbody/Frame Q's
