Fender flares on a sahara
I want to take a set of stock fender flares off a rubicon and put them on a sahara. (looking to put new flats on the rubicon) The sahara has the aluminum flares. Anyone have an idea of what I would need in the way of clips and pins? Would the inner liner that the sahara has work for the plastic fenders?
I thought they were fiberglass.
You can reuse the clips. They are the same. Some you can reach behind and squeeze to pop out. Others you can't and have to carefully lift the tabs up in front. They break easy so be careful. Rip-off to replace from dealer.
Thank you.
Originally Posted by sheepdog
Yes, you are right. I didn't really check them. I thought they were painted aluminum. I'll keep in mind the clips but it's an 07 and they aren't too cooperative.
Thank you.
