Feedbacks on the AEV 2.5 XT lift
Originally Posted by deangelo00
How do you like the lift? Did you get the Bilstein shocks? Your Jeep looks awesome, I am ready to buy a iift this weekend. I heard if you go higher than 3" you need to replace some drive shaft parts in the 2012 2Door, have you heard this at all?
Originally Posted by palehorse
Only 33.5"?! Yikes! I was just about to order the same tires. I know they're known for being shorter than 35", but only 33.5" once they're all mounted up is kinda ridiculous.
I'm definitely looking for something between 34" and a true 35", so I may need to re-think my plans.... :(
Anyone know of a comparable AT tire that measures much closer to 35"?
EDIT: What pressure are you running?
Originally Posted by opie88
Thanks a lot for the comment, this is only a 2.5" lift and didn't require new driveshafts. I did add the teraflex exhaust spacers but just for peace of mind, not because I had an issue. I'm not sure if the 2 door requires new driveshafts first hand but the AEV site states that it is not required with their 2.5" kit. Oh and yes this kit came with bilsteins.
Wow, that's even higher than many suggest for those (usually 32 or 33psi). I can't imagine them being even smaller. You may as well get a true 33" tire at that point!
I guess I need to do some more research...
