fades right!
fades right!
ok need some help here. just got the front end aligned and the tires rotated. acording to Brake Max. the alignement was good. so now i need help. i let go of my steering wheel and she fades right. it will change lanes in about 5 to 7 seconds by itself. what would cause this. there is a little steering wheel walking when i let go of it. i ordered a new S.S. to help with this. but i dont know what would be causing the fade even when everythings good..
Eternal ***erator
possible caster adjustment to fix it also. the angles on the front can be set with adj. arms so that there are slightly different angles to compensate for (not feel) the crown in the road quite so much. I have mine adjusted the same side to side, but it can be done slightly to compensate for daily driven roads.
just a thought
just a thought
Former Vendor
Check your cross caster! You should be running slightly more caster on the passenger side than the driver's side. That is done by design to account for road crown! Hope that helps.
Rock Krawler
Rock Krawler
I went through mine for months after putting on a budget boost and having this problem.
Adjustable lower controls arms help some
swapping the front tires from one side to another can fix it.
My jeep dealership actually installed adjustable upper ball joints to correctly adjust the camber for free!!!!!! this fixed the problem completely. It was a factory part, so you could try this route.
good luck
good luck
