Factory Springs to Teraflex Springs
So 2013 2 door Rubicon. Front springs are 14s and rears are 54s. I thought they'd be a higher number since it's a Rubicon. Is it because it's a 2 door? Not looking for anything to extreme at the moment for a lift. Wanting to run the stock Mud Terrains under they wear out. Just wanting to even out the rake and improve the breakover angle just a bit. I'm thinking with those weak springs, the Teraflex coil leveling kit would be just right. I've had the cheaper spacer leveling kit before on my 4 door. But since I trail ride more now, coils would be a better option. Thoughts?
The TF coil (performance lift) is a great kit. Only thing you have to replace are the 4 coils and front sway bar end links. It gives a mild lift and is able to handle the weight of aftermarket bumpers/winches. Below is my friends JKU where I installed the kit. I think it gives a good balanced look with the 33s...
