Factory Gas Tank Skid Plate Idea
So I know the factory skid plate on the gas tank it ok. But what if I could beef it up a bit? I've been out on the trail a few times now and I've made contact more than a couple times resulting in some dents and scratches. I'd personally feel a little more confident if that skid were to be a little thicker. I have a Unlimited so you know how big a target it is. My idea is weld 1/8" plate steel onto the skid. I've made a cardboard stencil of the exposed surface which I'll transfer to the plate steel. Then I want to cut it out with a plasma torch. Then take off the skid and weld the plate on (after I pound out the dents), Then paint.
So I was wondering if anyone has done this or thought about it?
If you've done it I would like some pointers.
I think that if you add 1/8" plate to the bottom that you will move the weak spot to the supports. I've taken my gas tank skid off 4-5 times already to pound out the dents and repaint.
With about 3-4 gallons of gas in the tank I can do it in about 30 minutes. That includes the time it takes to set up the jack.
The tank just free floats inside of the skid, so when you drop the skid you get the tank too. The front of the tank sits above the cross member, so you put the jack at the back of the tank and lower it. If I'm just working on the skid, I leave all of the fuel and vapor lines attached to the tank while I lower it.
I have given thought about the supports.But would it make it those weaker by a great amount? I'm still debating if I should or shouldn't.
I don't know if I could quantify the strengh of the supports. It's all about the weakest point in the system. If you add the plate to the bottom without strenghthening the supports, and you hit something hard enough to bend it, then the skid will bend at the supports.
It would be difficult to repair the supports. I have had dents up to 2" deep in mine and have always just pounded them back out. I've seen many other skids with large dents in them as well. I haven't seem or heard of anyone putting a hole in the factory skid plate.
I just don't see the need to add an additional plate over the skid. Not to mention the cost or the additional weight that you would carry arround.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
I'm planning on doing the same thing to mine soon. I'm not going to skin the whole thing, just back to where the first set of supports are. The leading edge of the skid is where most of my damage is anyway. Glad to know I can pull the tank/skid so easily. I skinned my T/C skid with 1/8th and it turned out nice.
I did this very job to my skid, I added 1/8 plate to the forward most section of the skid (skid is built in three sections)and welded two pieces of 3/4 x 2" C channel to the back section as sliders. has worked out well so far, have not had anymore serious denting. sorry no pics but this is an easy mod to do yourself and is way cheaper than aftermarket skids.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
