Factory Cam Bolts?
Factory Cam Bolts?
I was told by a local off road shop that my '07 Rubicon came from the factory with cam bolts on the lower control arm brackets... is this accurate?
Basically it came prepped to use cam bolts without having to measure and cut slots, the slots are available if needed.
Not 100%.... No it did not come with cam bolts per say, but from the factory there are perforations in the lower control arm brackets that are there for you to be able to knock out slots with a chisel, if you ever decided to or needed cam bolts.
My local guy is recommending that I keep the function of the cam bolts to allow some "give" and then add my adjustable LCA's to dial in my caster.
Now, I know using cam bolts on an off-road vehicle is asking for trouble and using both is redundant but does anyone really go wheeling with cam bolts for the "give"?
Hmm... I guess that partly excuses the guy at my local shop. I was calling around trying to find someone who could weld up the cam bolt slots so I can adjust my caster with adjustable LCA's "the right way".
And it's stupid to have both. Adjustable arms would give you ample adjustability. Sounds like your shop isn't up to speed with the times
Originally Posted by renpia
Holy crap! Don't go to that dealer unless you want poor handling or the start of death wobble.:
