OR fab tire carrier rusting!!
Got some of the rust off. Just used a wire brush and gently scrubbed it. Gonna reset my preload this week, and hopefully I get it right!
Thanks everyone.
Thanks everyone.
It's all about the preload. I also didn't tighten the hinge plate(passenger side) very well, so it had a slight tilt to the driver side. (instead of being parallel to the tailgate). I took the carrier off, put a 2x4 against the hinge plate and gave a solid which with a 2lb mallet. Tightened everything back up and was good to go.
I also glued(using a bead of silicone) a small piece of rubber bed liner on the metal landing block so the carrier is metal on metal when closes.
I tightened the bolts and now they are loose again. What gives? Do I have to put a lock nut on the backside of that plate? I tried getting them in there and wow....there's no room!!!
The directions have you putting nut on the back of the bolts once everything is tightened down completely. One of the nuts holds an additional support brace in place that secures the entire setup to the tub by the roll cage. Did yuo put these on? They are a pita to do but necessary. It was easiest to access them from the bottom of the quarter panel space through the hole that is there when you remove the foam insulation.
Last but not least did you call OrFab and talk to tech? Their customer support is top notch and I can't see them letting this go.
I experienced a small bit of surface rust at the beginning too. I scrubbed it off with a wire brush and hit the worn spots on the arm and landing block with rustoleum bedliner, and voila, no more rust spots. I also keep WD-40 on the hinges and not a single sign of rust has returned.
Also on the pre-load, when mounting mine I set it up about 3/4" high. That way when weight is added, it will not go past the landing block. Still, with my steel wheel and 33" tire + Hi-Lift Jack + 2G Rotopax it does not sag past the landing block.
Give one of the OR-Fab guys on here a shout and they will help you out, no doubt about it.
I've got the drivers side bolts and nuts In tight already. It's the passenger side I'm having trouble with. I can not get the nuts to the backside of those bolts(behind the passenger taillight) It's such an awkward angle for my wrist to bend. I'll give Or fab a call tomorrow, I'm swamped with all this moving crap.
Same thing here, a little WD-40 and not a bit of rust on my hinges. I love the fact that this carrier absolutely silent, no rattles at all.
