Or fab tire carrier questions....
To the people running this carrier. I just picked one up, and I'm about to install.
Did everyone here drill that pilot hole from the inside out per the instructions? If so, what did you use? A small drill? Dremel? Angle drill?
And.... How the heck do you mount the tire on the carrier? Just pick it up and place it while juggling the threaded t bar!?!?!?
Oh and by the way i love this tire / rotopax carrier.
Yes, you use a 90-degree drill and use a small bit from the inside. Only real way to make sure you get it lined up.
The tire/wheel actually sits on the little bar that bolts above the threaded bar. The T-bar is just to tighten the wheel against the carrier, it doesn't actually hold the weight of the wheel/tire.
Does it go through the lugnut hole or do you remove the center cap?
Be sure to put a piece of hose (5:8 fuel hose works) on the little bar for the wheel to sit on. I found the wheel would squeak sitting metal on metal and it keeps the bar (steel) from damaging the wheel (aluminum).
I just installed mine a few weeks ago.
I used a right angle drill. I install a lot of parts on my rig and buddy's and will say that I hope I never do another on of these. With that being said I live the orfab carrier on my jeep
Pain to install but well worth the effort. This is a rock solid tire carrier and I am 100% satisfied with the purchase!!
This is an old photo but here is my carrier easily supporting (2) 5 gallon jerry cans full of fuel, a 48" HiLift jack and a 33" tire. Just make sure you set some pre-load on the carrier based on your typical load so it lines up nicely with the landing block.
The install of this carrier is a nightmare. Got about 5 hours in yesterday, and were about 80% done I would say.
What a pain in the ass. You need tiny noodles arms and midget hands to fit in some of these area, that you can't even see.....
I didn't set a preload on the carrier, so I finish it up, and add the tire (35 inch) and see where it lands.....
I'll never install one of these again.....
