OR-Fab Swing Away Tire Carrier - Question for those of you who have this!!!!!!!
Old 04-08-2012, 06:47 AM
  #21
Wads13's Avatar
For all of you who posted and/or run across this... Here are some pics of how I remedied my security issue and gave myself some piece of mind.
Old 04-08-2012, 06:49 AM
  #22
Shortbuss's Avatar
Looks good! Definitely needs some kind of spacer. I cut mine from the day star bump stops I had left over then used eye bolts instead of bolts to make it easier to get on and off. I like the bar for the padlock thou.
Old 04-08-2012, 06:54 AM
  #23
Wads13's Avatar
Thanks, I had some other ideas with brackets and what not but decided this was much easier. A little more involved with fab'n it up as I drilled into the tire carrier, slid the 1/2" round bar in and welded it up and drilled the round bar for the pad lock (using a drill press) but other than that it was very simple to do. And yeah the spacer helps it from rubbin on the carrier, keeps it from rattling, and secures it on the mount a little better.
Old 04-08-2012, 07:15 AM
  #24
Fiveofun's Avatar
Anybody have a pic of the CB antenna mount that is supposed to be part of this carrier?
Old 04-08-2012, 08:55 AM
  #25
Wads13's Avatar
Curious about this as well... Currently mounted on LP housing, but looking to delete that one of these days.
Old 04-08-2012, 08:59 AM
  #26
isolated1523's Avatar
The cb "mount" I'm pretty sure is just a precut hole near the carrier latch that you would secure a normal CB stud mount through. At least that's what I figured the hole was for....
Old 04-08-2012, 09:09 AM
  #27
Wads13's Avatar
Makes sense... Makes for a long run for fishing the coax through but easy access to cb connector.
Old 04-09-2012, 03:44 AM
  #28
OH9JK's Avatar
It is this little tab with hole in it.
Old 04-09-2012, 05:43 AM
  #29
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=301521"/>
Must be different on the jerry-can version..I have the no-can version and the mounting hole is on the other side, on the flat plate by the latch. Interesting!
-Adam
Old 04-09-2012, 06:22 AM
  #30
Sahara_Maverick's Avatar
-Adam
I have the jerry-can version and mine has the mounts on both sides.
However, I noticed in some older photos that the mount on the right (in the photo posted above) was not present. So, could be a recent addition.
Quick Reply: OR-Fab Swing Away Tire Carrier - Question for those of you who have this!!!!!!!
