OR-Fab Jeep JK 4 inch Lift Kit???
Came across a place promoting this lift with install. I couldn't find anything on it. Re-branded lift from someone else? New lift released for 2013? Anybody have info on this lift.
As said by previous posters, OrFab is part of the same group that owns Trailmaster, Performance Automotive Group.
Which kit are you looking at? I have their 4.5" kit that has all 8 adjustable arms and replacement front and rear driveshafts. Overall I can say it is a decent kit for the money. I have almost 40K miles on mine with no complaints. Installation was straightforward and could be done in a driveway. My kit came with the SSV shocks, which were okay and held up but I definately felt I could do better. I looked at alot of options but after messaging Wayalife ended up just going with a simple set of Bilstein 5100s and it made an already decent ride much better.
Thanks all for chiming in. That's what I though it to be... a re-branded lift.
I'm guessing by the price I'm seeing, it is just a 4" spring lift. Probably can connect with people on this forum (like you WOL & others) who know Mel and crew at ORE to get me a deal on the EVO coils there, which I would trust a lot more I think than the TM ones.
Since I have a few responses, mind if I ask a secondary question to this. What else is needed for a stock JKUR if you do the 4" coil replacements from EVO? New Shocks? EVO Draglink flip? New Driveshaft? Control Arms? Other?
I am TOTALLY green and wet behind the ears on what all is required. So green in fact I'm still learning the names of these parts and what they do and where they go LOL.
Thank again.
Thank again.
To go 4" you will definately need shocks, you will also need control arms, and track bar brackets or adjustable track bars. I'm not sure if the driveshafts are absolutely required, I've read different opinions plus the kit I purchased came with them.
I'd definately message Wayolife, since he uses EVO equipment or message the EVO sponsor on this forum directly as I have no experience with their equipment. I can tell you that the EVO bolt on coil over kit looks awesome. Wayolife has it on Rubicat and he has a video of it running the rubicon. He has it set at 3.5" of height and is clearing 37s with flat fenders. I'm really considering that to be my next jump. I'd love to go coil overs and I'm thinking maybe of doing that next summer. I like the idea of a bolt on kit. Works best for me personally.
The 4" Plush springs from ORE are $379, but then you have to replace or upgrade all the other "stuff." Seems like a decent lift to get your junk a little off the dirt/rocks is all or nothing. I'm looking for that "budget boost" that is more than a body lift. Or like a starter kit that I can adapt and make better as I go along.
Sponsoring Manufacturer
OR-FAB
OR-FAB
Damn, that's what I figured...nothing is cheap! I know I know, J.E.E.P. stands for.....
Here is a kit that I think fits with what you are looking for - Trail Master J4611SSV
Under $750. Check with a local dealer.
It isn't necessarily all or nothing. I know there are people running 37s with a 2.5" kit and flat fenders. Heck with my 4.5" kit, if I added flat fenders and maybe a 1" body lift I could run 40s. It is just that after you hit a certain amount of lift the effects on steering geometry, driveshaft and pinion angles start to go beyond the stock components. You then need adjustable longer control arms, adjustable trac bars, etc to maintain a proper and SAFE handling.
Thanks for the comments and edumakation.
