explain to me - spacer VS coil lift
For example: the teraflex 2.5-inch spacer lift with shocke versus the teraflex 2.5-inch coil lift with shocks
What advantages does the coil lift have over the spacer lift? Why would it be better to go with the coil lift?
I went with a spacer lift first. I got in a hurry and wanted something "NOW" and jumped the gun. This is just my personal opinion, so take that for what it's worth. I prefer spring lifts because, ultimately, they are the correct way to raise a vehicle. I saw people talking about how you cannot feel the difference with a spacer lift. I ceretainly could. I didn't particularly care for how it made my Jeep ride. A bit harsh hitting bumps and I felt like I could "feel" every bump in the road. I had some trouble with rear spacers slipping, so, I made the decision to step up to the Teraflex 2.5" coil lift. I am glad I did. Still rides just a tad more firm than stock, but in a good way. Got more lift, too. More like 3.25" in the front and 2.75 in the rear. Makes the Jeep hamdle better because theres less sway around corners. Please understand I am not slamming spacer lifts by any means. There are some fine spacer kits on the market, I am sure. It is just "MY" personal opinion if you go with a spacer lift, you could regret it later on and wish you had gone with a spring lift. I did. That being said, a spacer lift may be all you'll ever need or want. Why don't you try to hook up with a forum member kinda close by with each kind and see if they'll let you ride and or drive theirs before you decide?
Interesting observation. I've never thought about it like that.
Alot of folks on here start off with a bb and slightly larger tires and then they realize that they actually want 35s or 37s , I fell victim to this as well, IMHO I would just skip over the bb and go with a coil lift and save some money.
spacer lifts are the quick and inexpensive way to lift vehicles.
spacer pucks only raise your vehicle because it puts a puck in between the frame and the top of the coil. our stock coils were not meant for this but CAN handle it. however, the spacer lift does not delivery the comfortability. in doing a spcaer lift, that puck actually compresses that stock coil making for a rougher ride. add in the weight from the bigger tires and you will see that this excess strain on the stock suspension system will not make for a comfortable ride when lifting the vehicle to clear for the larger tires.
i would have to say that doing a coil lift is the right way to lift a vehicle and that way those new coils and shocks are used exactly what they were made for. they are heavy duty and can handle the extra weight of larger tires which in tern should delivery a more comfortable ride and better performance.
Budget Boosts are not all that bad because they are in expensive. but to do it right i would recommend a coil lift.
notice the difference in the coils.
These are the rear coils with the new one on the left. The new one is wrapped tighter and is a progressive coil. It is designed to handle a heavier load.
Some people may get a harsher ride when adding a spacer lift on top of a coil lift but in my opinion it depends on what kind of coil lift you're working with. I have a 1.75" spacer on top of my 6" teraflex long arm kit and I attest that it rides 1000% better than a stock Rubcion and better than any other lifted JK I've ever ridden in (and there's been at lest 6).
If you have matched components along with a quality kit, some of the imperfections, if any, that the spacer brings out can be offset. This may not be the case when replacing just the coils and not the control arms along with the spacer and/or you're using an inexpensive coil kit.
I've ridden in scottg07's Rubicon that has the same 6" longarm kit as mine but with no spacer and I can't tell the difference between the two. Then again it wasn't on pavement but rather off-road....but then again still, off-road miles make up a majority of what I've driven the Jeep through so far.
