Exhaust spacer question
I got the exhaust spacer kit and my bolts are nothing but rust. They are completely rusted away. But that's besides the point. Can you have the exhaust spacers welded in at a exhaust shop? Would that work?
Cut em off. I broke off both bolts on my 2013, in 2013. With like 6k on it. Heat and bare metal are a perfect combination for corrosion.
I wish more people would just go to an exhaust shop instead of even bothering with spacers. Explain what you need and anyone worth anything will know what to do. My guy had never touched a jeep before and built me a whole system from the CAT's back. Clearance for days.
Heat them up really good with some MAP gad (yellow can) and then spray some Pb Blaster on them. It may catch fire, but just blow on it, it'll go out. Then more Pb Blaster. Do this a few times, then soak them real good for a few hours. The heat will suck the Pb Blaster into the threads and will help quite a bit.
I've since bought an after market shaft and would love to take mine off, but I'm not sure it's worth the hassle.
