Exhaust Nitrogen from Steering Stabilizers?
Old 05-17-2008, 09:25 AM
edstroyer's Avatar
Default Exhaust Nitrogen/Gas from Steering Stabilizers?
Im ready to replace my steering stabilizer with a Fox Nitrogen SS, Do I have to exhaust all the nitrogen?
Old 05-17-2008, 10:42 AM
BaltChief's Avatar
huh?.......
Old 05-17-2008, 11:13 AM
edstroyer's Avatar
I purchased a Fox Steering Stabilizer after seeing it on someone else's rig on the trail. The owner of the other JK mentioned something about emptying the gas out. Someone else on this forum thread mentioned the same. Im just tring the hear different opinions and logic on emptying the gas before doing so.
By the way, this is what I got after busting mines up... http://www.quadratec.com/products/16335_2000.htm
Old 05-17-2008, 11:26 AM
BaltChief's Avatar
I think I am following you now. If I am understanding you correctly you want to know if you need to reduce the pressure in your Fox stabilizer. From what I have read on here and from others maybe maybe not, you need to mount it and find out if it over compensates for your stearing. If the answer is yes, then you need to relieve some of the pressure.
Keep in mind I have no experience with the Fox SS, this is based only on what I have read. Others may be able to chime in with more info.
Old 05-17-2008, 11:31 AM
SGT.'s Avatar
I have it and like it the way it came, works with my tires and set up. You can fine tune it by adjusting the pressure, it shouldnt push your steering. I wouldnt let it all out, If you let some out of the stabilizer, you better like what you let out ,unless you have bottle to replenish it. if its too soft it not doing anything. Although you can find someone or a shop to help you. Its not hard. Good luck.....
Old 05-17-2008, 11:45 AM
edstroyer's Avatar
Thanks for the replies! I just finished installing the Fox SS along with woods relocation adaptor and am taking the the JK out for a ride to test it out.
I remember taking off the OEM steering stabilizer a few months back and how easily aI could compress it. The Fox SS requires a whole lot more to compress so Im expecting a big difference.
I'll post later on how it goes.
Old 05-19-2008, 12:46 PM
SGT.'s Avatar
how is it working......
Old 05-19-2008, 12:51 PM
greenmachine07's Avatar
yea how goes the pics??
Old 05-19-2008, 02:59 PM
JonnyCub's Avatar
Yep let everything out of mine. its not supposed to be in there.
Old 05-19-2008, 04:26 PM
edstroyer's Avatar
This was easy to install along with the Woods SS relocation bracket. The steering wheel is very stable at highway speeds. On hard bumps (while turning) the steering wheel returns to center pretty harshly. I'll slowly release/adjust some of the gas to get it to my liking.
Quick Reply: Exhaust Nitrogen from Steering Stabilizers?
